Hi looks like we have all left you at the windward mark.
Lets assume you got around ok. Is the next leg a reach or a run, we will do the reach first! You already know which jobs are helm, which jobs are crew, most are crew. There are a couple of jobs that need to be done in order for the helm to bear away, especially in a blow, so:- board off as you round, mast ram off, kicker re-set, outhaul to reaching position, shrouds off, jib tension on, pole out on leeward side. Balance forward/aft - leeward/windward.
The helm has been paying attention to who is close, do we go straight for the gybe mark, high or low. We maybe know if we have a "luffer" on our transom, if so keep this in mind, better to let one boat go than end up so high that we loose lots of places as we end up going to high for the mark. Norman Halstead has written an excellent article on best way to go! (I will see if I can scan it in)
Waves are as important as the wind especially if it is a planning reach. This however means you will not be going in a straight line, the optimum situation is to have the bow pointing “down hill” for as long as possible. Gravity assists the speed! You have to avoid driving into the next wave by going across the waves before bearing away to either catch the next wave, or if less lucky being back on top of the one you just “surfed”. Depending on your angle of approach and who is about you may have to give/ask for water; lets assume you are in the clear.
GYBE - full speed, the faster the better! Protect your new position if there are others close and make the same decisions as for leaving the windward mark. Crew weight is very important, especially in a blow, if there are swimmers at the mark then you need to decide if you want to go around the long way, dry! As Ron James says "wearing around is quicker than swimming". Once on the new reach and having made your decisions on “route” to the leeward mark, settle down as quick as you can, don’t assume it’s equal in terms of angle – wind etc. Assuming you arrive clear at the next mark all those adjustments need to go back on for the beat. Jib/shroud adjusted back on, outhaul back on, board down, kicker/ram re-set, and hopefully weight on the side hiked out ready for a clear air beat. Remember that if the wind has increased/decreased, you may need to tweak from you previous circuit settings. Well that’s enough for now, feel free to add/disagree with your thoughts.
Derek 7176
