Pulley Ratios 3 years 7 months ago #11176
  • SimonL7424
  • SimonL7424's Avatar Topic Author
Hi Folks.
I am in the process of rejuvenating the rigging on Wooden Tops (7424) and wondered what sort of pulley ratios are best for each rigging function.
For example, I studied the photos I took of the display boat at the Dinghy Show and worked out the ratio on the shroud tensioning line appears to be 10:1.
The ratio currently employed on Wooden Tops is 32:1.
Is that excessive?
Simon.
Pulley Ratios 3 years 7 months ago #11178
32:1 or 48:1 on the shrouds is usual.
If you then go for 16:1 or 24:1 on the jib you will be adjusting about the same amount of string on each control when you change the mast rake.
16:1 on the kicker is usual.
The boat at the dinghy show was an old fairey hull, too much shroud tension would not be good.
The following user(s) said Thank You: SimonL7424
Time to create page: 0.155 seconds
